StoryMap Publishing Issue
112
a month ago
mtso_gisucla
I recently noticed that a story map I published earlier in the year is throwing an error for public viewers. I can still login to view and edit the story and have republished it. This was previously published with no public viewing issues. When I select 'update sharing settings' I get an error but the message is vague and I'm not sure what the issue is. All of the layers and maps referenced in the story map are public. I'm not sure how to troubleshoot, any suggestions?
Link to Story Map: https://storymaps.arcgis.com/stories/618560a29f2a402faa2f5dd9ded0cc65
mtso_gisucla
Thank you Owen! It appears that I'm no longer getting the error message. I ended up republishing my maps in case one of the basemaps had an issue and perhaps that resolved the issue? Whatever it was everything appears to be working now. Thanks for checking in on this.
OwenGeo
Esri Frequent Contributor
@mtso_gisucla -- I'm sorry you're seeing this issue. I just opened the story in a private browsing window (not logged in), and everything appeared to load as expected.
Can you provide a screenshot or more information about the errors you are seeing?
Owen Evans
mtso_gisucla
