Is there a way to delete points that are more than a certain distance that a single point?
230
4 weeks ago
kazank
I’m trying to map out the campsites in the Bay Area, CA but the only geodatabase for the state parks was for all of the campsites in California. I want to delete all of the points in SoCal and probably within a 150ish mile radius of where I am. Is there a way to do that? Or would I have to just do it manually?
jcarlson
@marksm_macomb  has posted a reply in a separate thread: https://community.esri.com/t5/arcgis-pro-questions/re-is-there-a-way-to-delete-points-that-are-more/... perhaps you should check it out.
- Josh Carlson
Kendall County GIS
kazank
@kazank wrote:
I’m trying to map out the campsites in the Bay Area, CA but the only geodatabase for the state parks was for all of the campsites in California. I want to delete all of the points in SoCal and probably within a 150ish mile radius of where I am. Is there a way to do that? Or would I have to just do it manually? https://vidmate.onl/
I got this,...
