ArcGIS StoryMaps Extract Location Data or Pass to Web Map
100
07-22-2021 07:54 AM
BrianKaplan2
I created a ArcGIS Storymap Map tour adding the locations manually as lat and long.   I would like to add a link to a separate web map with the map locations.   Is there any StoryMap quick steps to live link the locations to a web map?    Or is there a way to extract the x and y coordinates with a few clicks.  I can see the x and y in the JSON (via AGO Assistant).    I suppose I may be able to use javascript via a browser like this method but I get an error "VM530:1 Uncaught ReferenceError: app is not defined at <anonymous>:1:32" maybe because it is for the classic storymaps.
I can extract the x and y from the JSON file manually or spend some time extracting the x and y with the title and narrative with code but since I'm not a programmer it will be difficult or maybe impossible for me to figure it out.  Since I only have 14 slides, manual may be the most time efficient at the moment.
Thanks.
