I like that you can have a title and a description in the Map Tour. However, since you cannot have pop-ups in the map I'd like to have a multi-line description in the side bar.
For example, right now I can show the title and address. But, it would be great to be able to show the address as well as the website (as a link).
@JaredPilbeam2 -- Thanks for sharing this additional information. This is actually a duplicate idea of the render HTML idea. If you wouldn't mind, please add this comment to that idea so this use case is documented there.
Render HTML from a feature service field used for ... - Esri Community
