This is a very common regulatory workflow that can be solved using GIS. Searching around it appears some have done it on their own, but would love to see Esri tackle this as part of a deployable OOTB solution. Here's a summary of SPCC from the EPA, which applies to any facility that:
(1) Stores, transfers, uses or consumes oil or oil products, such as diesel fuel, gasoline, lube oil, hydraulic oil, adjuvant oil, crop oil, vegetable oil or animal fat; and (2) Stores more than 1,320 U.S. gallons in total of all above ground containers (only count containers with 55 gallons or greater storage capacity) or more than 42,000 gallons in completely buried containers; and (3) Could reasonably be expected to discharge oil to navigable waters of the U.S. or adjoining shorelines, such as lakes, rivers and streams.
