Hi Team,
I am new to ArcGIS, I have few shapefiles now my task is to read the shapefiles contents and convert it to xml file (CIM format). I don't want to display this shapefiles in UI, I just need to read the contents of the shapefiles. I am basically from C++ background, hence I prefer to use ArcGIS Runtime API for Qt.
1. Can I able to read the shapefiles using ArcGIS Runtime API for Qt ?
2. Is it possible to provide some hints or code snippets or API reference to achieve this task.
Any support in this regard is very helpful...
Solved! Go to Solution.
Hi @VikasGanesh ,
I think some of this may be doable with the Runtime, but the workflow sounds better suited to ArcGIS Pro utilizing the export tools.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/export-data.htm
However, if you need a Runtime solution, you can use ShapefileFeatureTable class, and that will give you access to all the features in the Shapefile feature table.
https://developers.arcgis.com/qt/cpp/api-reference/esri-arcgisruntime-shapefilefeaturetable.html
Once it's loaded you can use the inherited methods from FeatureTable, like queryFeatures to find all features, read their info and write them out (somehow) directly to xml.
When using queryFeatures, you can provide "1=1" as your whereClause to query all features.
I think that would get you there, but I still think ArcGIS Pro would be the best option is it is better suited to data export workflows.
I hope this helps.
Hi @VikasGanesh ,
I hope this helps.
Thanks JamesBallard1, this is really a very useful information for me to start...🙂
