Value does not fall within expected range
4234
11-28-2018 02:06 PM
KiroAndreev1
I use Arcgis runtime for net 100.2 and create C#/WPF application.
I developed custom circle (code of circle is) :
double slice = 2 * Math.PI / 360;
Esri.ArcGISRuntime.Geometry.PointCollection pcol = new Esri.ArcGISRuntime.Geometry.PointCollection();
Polyline polyline = new Polyline(points_Circle);
double radius = Convert.ToDouble(GeometryEngine.Length(polyline));
double sliceRadius = 0.07;
double radian = Math.Acos((radius - sliceRadius) / radius);
double angle = radian * (180 / Math.PI);
//Calcuate tendon
double tendon = radius * Math.Sin(angle);
if (tendon < 0.1)
tendon = 0.1;
angle = Math.Asin(0.1 /radius);
for (double i = 0; i <= 360; i += angle)
double rad = slice * i;
double px = points_Circle[0].X + radius * Math.Cos(rad);
double py = points_Circle[0].Y + radius * Math.Sin(rad);
pcol.Add(new MapPoint(px, py));
Polyline p = new Polyline(pcol);
// Create the graphic with polyline and symbol
Graphic graphicPoly = new Graphic(p, lineSymbol);
Image of circle is:
When intersect this circle with rectangle (code of rectangle is):
  var rectangle = await MyMapView.SketchEditor.StartAsync(SketchCreationMode.Rectangle, false);
appear next message:
How to solved this problem?
dotMorten_esri
Esri Notable Contributor
I don't see you ever assigning a spatial reference to the geometries. Does the problem go away if you assign the correct spatial reference?
KiroAndreev1
Morten,
I put spatial reference "SpatialReferences.WebMercator" into:
 Esri.ArcGISRuntime.Geometry.PointCollection pcol = new Esri.ArcGISRuntime.Geometry.PointCollection(SpatialReferences.WebMercator);
and solved problem
Thank you!
