Problem while loading large ECWs in Scene View
371
08-31-2021 08:30 AM
TasawarAhmad
AOA,
1- I am trying to simulate a 3d plane on scene. I have a worldMap ecw (40MB) on which another ECW file approx 40GB is being loaded using dynamic workspace approach. I m also loading a fairly large DEM(.tif) file as well.
2- I have been able to show the plane on the ECW file properly, however approx only 1x1 KM area is shown.  Whenever the camera is slightly moved, then rendering is redone. Interestingly, even when I only load worldMap.ecw (40MB) without any other layer or DEM, this problem still occurs.
I m attaching the pictures as well.
3- Is there any solution for this problem? I m using ArcGIS Runtime 100.10 and latest local server component.
Thank you
TasawarAhmad
For anyone else facing this issue, I have changed my map format from .ecw and loaded it with the use of runtime api rather than local server. Now I m not facing this issue.
TasawarAhmad
