After a bit of deliberation I was finally able to get the OAuth credential generation working in a net6 wpf application. See Challenge Handler not called in WPF I took a bit of a different approach than discussed there, shown below
// Calls await ArcGISPortal.CreateAsync(new Uri(ServerUrl));
_portal = await _authenticationHelper.OpenPortalAsync();
//Done to fire the ChallengeHandler before loading anything
_= await PortalItem.CreateAsync(_portal, "itemid");
Map = new Map(new Basemap(BasemapStyle.ArcGISStreetsRelief))
InitialViewpoint = ...
_projectsFeatureLayer = new FeatureLayer(new Uri(ProjectsShapeUrl));
_photosFeatureLayer = new FeatureLayer(new Uri(PhotoUrl));
Map.OperationalLayers.Add(_photosFeatureLayer);
Map.OperationalLayers.Add(_projectsFeatureLayer);
await Map.LoadAsync();
This will fire the OAuth dialog and the user logs in then everything loads and no APIKey is needed.
The issue is that even though I am logged in and can load layers without issue the _portal object does not seem to hydrate completely. There is no PortalUser on the object, and if I try to get a license it fails saying the user cannot
According to help
At this point the user is authenticated because the maps have loaded, load status is Loaded. Also if I try to get a license it fails
Which is not true, the user does have access to a Standard Runtime license.
There is nothing I could find, beyond loading a map that would be required for initialization, as described in help. Am I missing something?
