ArcGISVectorTiledLayer not showing when assigned to Map in async method
81
09-29-2022 02:49 AM
ViktorSafar
New Contributor III
I have a WPF app using MVVM/Prism and .NET Runtime SDK.
Simple VM with a Map property which is bound to a MapView.Map in the control. I am adding 2 layers to the Map's base layers collection. I am adding a `ArcGISMapImageLayer` and a `ArcGISVectorTiledLayer`.
When I assign the layers in the VM constructor, everything works fine. When I assign the layers in an async method called from the constructor (via fire and forget), only the `ArcGISMapImageLayer` gets shown in the MapView when the UI lods, not the `ArcGISVectorTiledLayer`. I've played with it a lot, changing order of addition, explicitly calling it on the UI thread, but it all behaves the same when the layers are added in an async method.
The reason for an async method is that I want to load the layers but have removed the extra code for clarity. The SetupLayers() method is commented out on purpose in the given snippet. When the constructor calls it, the problem occurs.
namespace NFS_POC.Views
    internal class MainMapVM : BindableBase
        public MainMapVM()
            Map = new Map
                InitialViewpoint = new Viewpoint(59, 6, 1000000)
            // SetupLayers();
            // this works fine
            var imageLayer = new ArcGISMapImageLayer(new Uri("https://services.server.tld/arcgis/rest/services/something/something2/MapServer"));
            Map.Basemap.BaseLayers.Add(imageLayer);
            // this works fine
            var vectorTiledLayer = new ArcGISVectorTiledLayer(new Uri("https://services.server.tld/arcgis/rest/services/foo/bar/VectorTileServer"));
            Map.Basemap.BaseLayers.Add(vectorTiledLayer);
        private async Task SetupLayers()
            // this works fine
            // this does not work???
        private Map _map;
        public Map Map
            get { return _map; }
            set { SetProperty(ref _map, value); }
JoeHershman
MVP Regular Contributor
One thing you are not doing is calling .LoadAsync().  Personally I don't like directly calling a async method from a constructor.  The way I do something similar.  Create a simple event LoadMapEvent
public MainWindowViewModel(IEventAggregator eventAggregator)
	//Allow async for loading map
	eventAggregator.GetEvent<LoadMapEvent>().Subscribe(OnLoadMap);
	eventAggregator.GetEvent<LoadMapEvent>().Publish();
private async void OnLoadMap()
	try
		//add layers
		await Map.LoadAsync();
	catch (Exception e)
		_log?.Error(e, e.Message);
ViktorSafar
New Contributor III
Yeah, agreed that calling an async method from a constructor is not a good design. I am in a recon/play mode trying to see what the framework can do.
However, I would argue that you're basically doing the same. The event aggregator is fire and forget
