JavaFX is actually a Java platform to create desktop applications.
Sorry. I will try again: Runtime SDK for Java. Hopefully that's closer.
Can we know a little about your application.
Are you able to reproduce the issue with this app in git or is is more specific to a dataset you are using?
It is possible to override the interactions in the JavaFX control to make your own, but let's explore if this is a data issue first.
If you can share some code and confirm the version of the SDK you are using, that would help too.
@hedonicCrab for reference I've included your short video so we can continue to help you in this thread.
You've said that you see this on mac macOS and Ubuntu.
I can confirm that this looks very wrong and certainly isn't expected.
At the very end of your video there looks like its performing an animated zoom operation; this won't have been triggered by mouse wheel, so do you have some other viewpoint setting code which is fighting the mouse interactions?
