portal.fetchLicenseInfo completion closure is not invoked.
556
09-23-2021 04:35 PM
ShiminCai
Hi All,
I'm checking out an ArcGIS Runtime license from our ArcGIS Online account using the code below that is copied from ArcGIS Runtime SDK for iOS documentation:
//get the users license info from the portal
portal.fetchLicenseInfo { (licenseInfo,error) in
    guard let error = error {
        print("Error fetching user's licenses... \(error)")
        return
    //set the license using the Named User's licenseInfo
    do {
        let result = try AGSArcGISRuntimeEnvironment.setLicenseInfo(licenseInfo!)
    } catch let error as NSError {
        print("error: \(error.localizedDescription)")
    //The app is now licensed
    // Save the license information so that the app can be started and licensed offline
    // In this example the licenseDictionary is stored in keychain
    var licenseDictionary: NSDictionary?
    do {
        licenseDictionary = try licenseInfo?.toJSON() as! NSDictionary?
    } catch {
        print("LicenseInfo not available")
    let keychainItem = AGSKeychainItem(identifier: "com.your_org.your_app_name", accessGroup: nil, acrossDevices: false)
    keychainItem.writeObject(toKeychain: licenseDictionary!, completion: { (writeError) in
        if let error = writeError {
            print("Error writing to the Keychain... \(error)")
The problem is that the completion closure of the portal.fetchLicenseInfo() method never gets invoked and as a result I never get a license or an error...
However, I can get a valid license from the portal property: portal.portalInfo?.licenseInfo, but 'licenseInfo' is deprecated: This property has been replaced by `AGSPortal#fetchLicenseInfoWithCompletion:` from Xcode.
Does anybody have any idea please? I'm using SDK 100.10.
Shimin
Nicholas-Furness
Are you holding on to the `portal` instance? If it gets deallocated before the round trip to the server, then the completion handler won't get called. Can you make it an instance variable?
Nicholas-Furness
ShiminCai
Thanks Nick for your reply. I don't think the portal variable is deallocated because I can get a valid license from portal.portalInfo.licenseInfo. I'll try to make it an instance variable...
ShiminCai
Hi Nick,
Making it an instance variable helped. Thank you so much for your help.
Cheers,
Shimin
