portal.fetchLicenseInfo completion closure is not invoked.
128
3 weeks ago
ShiminCai
Occasional Contributor II
Hi All,
I'm checking out an ArcGIS Runtime license from our ArcGIS Online account using the code below that is copied from ArcGIS Runtime SDK for iOS documentation:
//get the users license info from the portal
portal.fetchLicenseInfo { (licenseInfo,error) in
    guard let error = error {
        print("Error fetching user's licenses... \(error)")
        return
    //set the license using the Named User's licenseInfo
    do {
        let result = try AGSArcGISRuntimeEnvironment.setLicenseInfo(licenseInfo!)
    } catch let error as NSError {
        print("error: \(error.localizedDescription)")
    //The app is now licensed
    // Save the license information so that the app can be started and licensed offline
    // In this example the licenseDictionary is stored in keychain
    var licenseDictionary: NSDictionary?
    do {
        licenseDictionary = try licenseInfo?.toJSON() as! NSDictionary?
    } catch {
        print("LicenseInfo not available")
    let keychainItem = AGSKeychainItem(identifier: "com.your_org.your_app_name", accessGroup: nil, acrossDevices: false)
    keychainItem.writeObject(toKeychain: licenseDictionary!, completion: { (writeError) in
        if let error = writeError {
            print("Error writing to the Keychain... \(error)")
The problem is that the completion closure of the portal.fetchLicenseInfo() method never gets invoked and as a result I never get a license or an error...
However, I can get a valid license from the portal property: portal.portalInfo?.licenseInfo, but 'licenseInfo' is deprecated: This property has been replaced by `AGSPortal#fetchLicenseInfoWithCompletion:` from Xcode.
Does anybody have any idea please? I'm using SDK 100.10.
Shimin
Nicholas-Furness
Are you holding on to the `portal` instance? If it gets deallocated before the round trip to the server, then the completion handler won't get called. Can you make it an instance variable?
Nicholas-Furness
ShiminCai
Thanks Nick for your reply. I don't think the portal variable is deallocated because I can get a valid license from portal.portalInfo.licenseInfo. I'll try to make it an instance variable...
ShiminCai
Hi Nick,
Making it an instance variable helped. Thank you so much for your help.
Cheers,
Shimin
