com.esri.arcgisruntime.ArcGISRuntimeException: Invalid argument.: weak_ptr is expired.
490
07-05-2022 12:36 AM
tashi146
While trying to load pre planned esri map. I am getting error "com.esri.arcgisruntime.ArcGISRuntimeException: Invalid argument.: weak_ptr is expired.".
First time it was working fine, after that I am getting this error. Just wanted to know what is the related issue here.
Tags (3)
GuntherHeppner
Could you share your code. Is it possible that you are not holding on to some object(s) like the OfflineMapTask or corresponding jobs, thus making them eligible for garbage collection?
tashi146
Hi, Thanks. Issue is fixed, I am not using the object properly.
