Luxon Inefficient Regular Expression Complexity vulnerability
1342
7
01-18-2023 04:37 PM
FabianHanggi
Hello
I'm getting an error  today in my pipeline that runs npm audit -prod
luxon 2.0.0 - 2.5.1
Severity: high
Luxon Inefficient Regular Expression Complexity vulnerability - https://github.com/advisories/GHSA-3xq5-wjfh-ppjc
fix available via `npm audit fix --force`
Will install @ArcGIS/core@4.25.5, which is outside the stated dependency range
node_modules/luxon
@ArcGIS/core 4.21.0-next.20210721 - 4.25.0-next.20221108
Depends on vulnerable versions of luxon
node_modules/@arcgis/core
All version of ArcGis are using luxon versions that have this vulnerability. In git hub for luxon it says to update to newer versions
Is ArcGis going to release an update soon? if not i cannot release my app since i'm not allowed to deploy high severity vulnerabilities.
Is there a work around while you work on an upgrade?
Thank you
Fabian
FabianHanggi
Response from ESRI support
Hello Fabian,
I did receive a response from Esri inc. and this issue has already been resolved in the next release. When the next release comes out you will just need to upgrade. The next release has been updated to 3.2.1.
The next release of the JavaScript SDK is scheduled for late February or early march of 2023.
Let me know if you have any further questions.
Thank you,
Victor C.
Esri Canada
Stacy-Rendall
New Contributor III
Also encountering this issue
by Anonymous User
Not applicable
Same issue here.
René_Ténière
Any traction on this from esri yet?
by Anonymous User
Not applicable
4.26 does not depend on version(s) of the Luxon module affected by CVE-2023-22467.
You can validate this by installing the 4.26 release using the following command:
 npm install @ArcGIS/core@next
René_Ténière
I am still in development so I will wait for the official release.
FabianHanggi
Hello Fabian,
Thank you,
Victor C.
Esri Canada
FabianHanggi
Just installed 4.26.5. This issue has been resolved
