Using a published CSV file for project input lists in QuickCapture
252
09-28-2022 04:39 PM
Ryan_Gould
Greetings, I would like to use a CSV I've published in Portal for a list in a user input in QuickCapture. Manually pasting a new list into QuickCapture each time there is a change is cumbersome. Is there a way to reference the CSV I've published in the QuickCapture project or JSON?
Thank you for any help.
IsmaelChivite
Esri Notable Contributor
Hi. Not possible. However, we are currently working on allowing you to populate lists from a layer query. This will work online and offline. You may want to wait for that? Or even better, participate in the Beta so you can provide your feedback to us. Please join us at our next holistic testing exercise https://arcg.is/KGr9K  or simply contact us for details at quickCapture@esri.com
