sde Feature class for Quick Capture with camheading
295
11-21-2022 02:55 AM
Polesig
I'm trying to store data collected in Quick Capture in an Enterprise geodatabase with a referenced Feature Service.
I would like to get one single field filled : camheading using the camheading value available in Quick capture designer.
The feature class has this single field with type Double.
However when I try to collect a record using the mobile app, I get an error message : defining value of camheading failed. Inspecting ArcGIS Server logs, I can see an error "value type incompatible with field type".
Has anyone experienced the same behaviour and is there a way to solve it ?
Thanks a lot
JohnathanHasthorpe
Hi Polesig, this is not expected behaviour.
It would be good to get on a call to help you troubleshoot this further. Could you send us an email via: QuickCapture@esri.com and we will get back to you.
John
Polesig
Hi Johnathan,
I sent the message but did not get any answer.
Thank you
