Multilingual QuickCapture projects
922
09-09-2021 06:12 AM
Embeez
New Contributor III
Are there any plans to make QuickCapture multilingual? Survey123 has this funtionality and it would be very useful to have a similar option for QuickCapture?
Tags (1)
JohnathanHasthorpe
Hi Embeez - marking this as solved as idea has been raised: https://community.esri.com/t5/arcgis-quickcapture-ideas/multilingual-quickcapture-projects/idi-p/109...
We use status to track outstanding questions, so need to make this change.
Thanks
John
Mandy_Li
Hi @Embeez QuickCapture is localized already, see its Supported languages.
  • For the mobile app, the language used is determined by your device's language setting.
  • For the web designer, the default language is determined by your ArcGIS organization user language setting. When a user is not signed in to an ArcGIS organization, the web browser settings are used by the web designer.
Tags (1)
JohnathanHasthorpe
Hi Embeez,
I guess you mean making the project content multlingual like you can in Survey123. At the moment the only option is to create a different project for each target language.
Could you please raise it as an idea (along with details of your workflow) and we will review.
Thanks
John
Embeez
New Contributor III
Hi John,
Yes indeed - I mean the button labels and group titles. We work in a multilingual environment and although English is often acceptable, the more our use cases expand, the more we need more flexibility on language.
I'll post an idea as you suggest.
Thanks
Tags (1)
Embeez
New Contributor III
Receiving a reply to post an idea should not be classed as "solved" in my opinion!
JohnathanHasthorpe
Thanks
John
