ArcGIS QuickCapture 1.16 is scheduled for release before the end of 2022. We will host two live holistic testing sessions in November for all of you who want to experience the upcoming features first hand and provide feedback. You can register here.
Here are some of the features in the works.
Faster user inputs
Not long ago we added support for chaining project and button user inputs. With this update, you will no longer need to tap on Done in order to move from one to the next. As soon as you make a selection on your user input, it will jump to the next. Fewer taps, quicker data capture!
Auto-update projects (Planned release 1.16)
The world changes quickly, so it is no surprise that you need to make changes to your QuickCapture projects, even while they are actively being used. Ensuring that everyone in the field is using the latest version of your QuickCapture project could have been a challenge in the past, but not anymore.
Activate auto-updates and QuickCapture will take care of keeping projects up to date in your users’ devices. It is that simple. It is that quick!
To enable auto-updates on QuickCapture, you must be an ArcGIS Administrator. Check below how you can access this new organization setting.
Barcode scanning (Planned release 1.16)
Scan and move on. That is the basic idea. With this update you can configure your QuickCapture projects with barcode scanning capabilities. Data from a barcode can be used to populate attributes in the features you collect. This allows you to quickly collect data from existing assets and move on.
As a project author you can enable the barcode scanner on any text-based user input. Check below how to do it:
Video (Planned release 1.17, but available for the brave of you in 1.16)
A picture is worth 1,000 words. What about a video? QuickCapture now supports video recording. Use it to document issues, damage or for other events. Videos are uploaded into ArcGIS as attachments, so you can view them from other ArcGIS apps and dashboards.
We will add all the bits in version 1.17 (early 2022), but as of 1.16 you can activate video recording by hacking your project's JSON a bit as shown in the animation below:
Auto-populate attributes using Arcade expressions (Planned release 1.17)
You already know that QuickCapture can automatically populate attributes of the features you collect: Horizontal Accuracy, Time of Observation, User’s email, Device info and much more… Now, what if you could also use Arcade expressions to make your QuickCapture buttons gather even more information? Use Arcade to perform spatial calculations, enrich attributes via lookup searches, etc.
Dynamic lists (Planned release 1.17)
We use lists constantly to help field users collect data in a consistent manner. Priority high, or priority low? Follow up needed: Yes, or no? What is the condition of the asset: Good, fair, needs repair? Some lists are larger: A list of plant species, a list of violations… Some lists change constantly: A list of inspectors, a list of assets… No matter what list you need to deal with, QuickCapture has a good solution for you. In this release, we are introducing dynamic lists. This is a list that gets populated using a layer query. Here are some examples:
Of course, team members, assets and plant species can be all managed in ArcGIS layers. QuickCapture will simply query your layers to populate the lists. The results of your queries will be automatically cached so your lists will work even if disconnected!
Floor-aware map support (Planned release after 1.17)
Use ArcGIS QuickCapture indoors and take advantage of floor-aware maps built with ArcGIS Pro.
Again, you are all invited to join us in October. Complete this form to register .
