Upload csv to portal
288
8
3 weeks ago
MK13
Is it possible to upload a csv file to portal or create a feature service using the pro sdk? I couldn't find any samples in the documentation.
@CharlesMacleod @UmaHarano @Wolf
UmaHarano
Hi @MK13
Here is a code snippet - I will add this to our docs too for posterity.
// Create EsriHttpClient object
   var httpClient = new EsriHttpClient();
   // Upload CSV file to ArcGIS Online
   var itemToUpload = ItemFactory.Instance.Create(@"C:\Data\AddToMapCustomItem\AlaskaCitiesXY.csv");
   string[] tags = new string[] { "ArcGIS Pro", "SDK", "Internal Demo" };
   UploadDefinition uploadDefinition = new UploadDefinition(
     ArcGISPortalManager.Current.GetActivePortal().PortalUri.ToString(),
     itemToUpload,
     tags
   var result = httpClient.Upload(uploadDefinition);
   if (result.Item1 == false)
     return;
   Thread.Sleep(2000);
UmaHarano
@MK
Can you please explain a little more? You have custom data in a csv?
MK13
@UmaHarano yes. I have custom data that I generate in a pro sdk addin that I would like to save to ArcGIS Portal either as a csv file or a feature service.
UmaHarano
@MK13
As you might already know, a plugin data cannot be shared as a web layer.
But, a csv file can be shared to an ArcGIS Enterprise portal- Here is a document that lists all the supported items on an  ArcGIS Enterprise portal:
Content you can add in the ArcGIS Enterprise portal
MK13
@UmaHarano do you have some example code to share a csv file to portal using the pro sdk?
UmaHarano
@MK13
You will have to use EsriHttpClient to upload the csv file. I don't have a code snippet for it yet - will try and share some code in the next couple days.
MK13
Hi @UmaHarano , have you had a chance to find a code snippet for an upload to portal? The documentation has lots of examples for get requests but no post examples.
UmaHarano
Hi @MK13
     itemToUpload,
     tags
     return;
   Thread.Sleep(2000);
MK13
Works perfectly. Thanks!
