select layer by geometry
418
05-23-2022 08:49 AM
PeteVitt
Occasional Contributor III
Hi - I would to select features from a specific layer using the map tool.  I've found the snippet below, but it selects features from the top-most layer in the toc only:
return QueuedTask.Run(() =>
var mapView = MapView.Active;
if (mapView == null)
return true;
//Get all the features that intersect the sketch geometry and flash them in the view.
var results = mapView.GetFeatures(geometry);
return true;
is there anyway to specify the layer by name like the code below and then perform the select/get features on the specified layer only:
var layer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().First(l => l.Name.Equals("MSA_Class"));
Thanks
Pete
Tags (1)
StephenRhea_NV5
You could use a `SpatialQueryFilter` to search on the layer.
var spatialFilter = new SpatialQueryFilter
    FilterGeometry = geometry,
    SpatialRelationship = SpatialRelationship.Intersects
using (var featureCursor = layer.Search(spatialFilter, false))
    while (featureCursor .MoveNext())
        using (var feature = featureCursor.Current)
            // Feature-specific code here
PeteVitt
Thanks Stephen - I'm getting a called on wrong thread exception error  on the layer.Search method
return true;
while (featureCursor.MoveNext())
return true;
StephenRhea_NV5
Are you running that query within a background or worker thread? I'm pretty sure most map interaction has to be done on the main calling thread (MCT), and the QueuedTask runs its function there. However, if you're using this in a separate thread you've created, you may not be able to access the map.
PeteVitt
the exception went away when I changed:
to
using (var featureCursor = layer.Search(spatialFilter))
still only getting the top layer selected -- I'll take a look at the selectability of the layers as suggested below
sjones_esriau
GetFeatures returns a collection of visible and selectable features that intersects a geometry.
If you're only getting the top layer, that may be the only layer selectable in the TOC.
