RowDeletedEvent.Subscribe
351
11-26-2021 11:57 AM
JeanDesormeaux
New Contributor II
I have a strange behavior. In my environment, I subscribed a table to the RowDeleteEvent and it's working fine.
I  did a backup of my database and restored it in client environment.
On his side, the RowDeleteEvent is not triggered and we are able to delete data immediately.
I did a remote debug of my code with his database (via VPN), and the event subscription is done successfully, but still not raised when deleting the data.
Any idea why the behavior is not the same on both side?
Regards,
Jean
JeanDesormeaux
New Contributor II
Hi again,
Finally I recreated a new projet in ArcPro and now all triggers working well.
Anyone has any idea what could be wrong?
Thank you,
Jean
JeanDesormeaux
New Contributor II
Hi guys,
I finally found my issue.
In background, my objects are linked with an updated SDE connection file that doesn't use the same credentiel has the Layer. So I needed to reset the layer's DataSource to the new connection and now I'm back on track.
