MemoryConnectionProperties custom name vs. ExecuteTool in memory
142
09-16-2021 11:21 PM
ole1986
I am trying to get a memory geodatabase with custom name to work with Geo processing tools (executed in codebehind).
So, I have created a `MemoryConnectionProperties` object as follow
MemoryConnectionProperties _memoryConnectionProperties = new MemoryConnectionProperties("MyCustomName");
But yet I could not find out how to access it using `ExecuteToolAsync`?
Usually for memory I have used the following
var parameters = Geoprocessing.MakeValueArray("memory\\" + _targetFeatureClass.GetName(), shapeFileOutputDir, shapeFileOutputName);
var result = await Geoprocessing.ExecuteToolAsync("FeatureClassToFeatureClass", parameters, null, null, null, GPExecuteToolFlags.None);
Which is fine with the default memory.
Since I would want to isolate several "tasks" the idea came up to use a custom memory name. But I could not find out how to define the memory location (with its custom name).
What I have tried without success
// does not work when executing "FeatureToFeatureClass" tool
var parameters = Geoprocessing.MakeValueArray("memory\\MyCustomName\\" + _targetFeatureClass.GetName(), shapeFileOutputDir, shapeFileOutputName);
// also does not work when executing "FeatureToFeatureClass" tool
var parameters = Geoprocessing.MakeValueArray("MyCustomName\\" + _targetFeatureClass.GetName(), shapeFileOutputDir, shapeFileOutputName);
Any ideas how to solve it?
RichRuh
Sorry, geoprocessing can only access the memory geodatabase called "memory."
--Rich
RichRuh
--Rich
