How to open tool dialog for raster functions and change detection wizard?
222
06-13-2024 04:34 AM
MuhammadElbagoury
New Contributor II
Dear All,
I am trying to create an add-in that opens the tools dialogs like ndvi (raster functions) or Change detection wizard.
I tried to do this workflow on Geoprocessing tools like Buffer and it worked.
Here is the code for this:
"Geoprocessing.OpenToolDialog("analysis.Buffer", null);"
So how to make like this to open raster functions ??
Thank you.
Tags (3)
MuhammadElbagoury
New Contributor II
I made it with the ID by adding this line to the "Config.daml" file :
<tool refID="esri_datasourcesraster_changeDetectionToolsGallery" size="large" />
UmaHarano
Try using the tool name mentioned in the Python tab on the tool documentation.
MuhammadElbagoury
New Contributor II
Thank you for your support:
This worked "Geoprocessing.OpenToolDialog("ComputeChangeRaster", null);"
But I still cannot open the pane for the Change Detection Wizard.
I also got an idea:
Can I open it using its ID as the ID of the wizard is "esri_datasourcesraster_changeDetectionToolsGallery" ??
MuhammadElbagoury
New Contributor II
