EditOperation IsEmpty after attribute change
220
12-06-2023 08:32 AM
DaveWilcox
I'm calling this code from a button on a dockpane. The current attribute value is null and I am changing the value to a number, so there should be a change, but the modifyFeature Edit Operation is empty after the Modify. Any ideas on what might be causing this?
        public static void SetFieldInt(Map? map, string layerName, string fieldName, int value)
            try
                if (map is null) return;
                BasicFeatureLayer? featureLayer = (BasicFeatureLayer?)FindLayer(map, layerName);
                if (featureLayer is null)
                    return;
                else
                    Selection selectedFeatures = featureLayer.GetSelection();
                    var modifyInspector = new Inspector();
                    using (RowCursor rowCursor = selectedFeatures.Search())
                        while (rowCursor.MoveNext())
                            if (rowCursor.Current is not Feature feature) return;
                            long oid = feature.GetObjectID();
                            if (feature != null)
                                object den = feature[2];
                            modifyInspector.Load(featureLayer, feature.GetObjectID());
                            var modifyFeature = new EditOperation
                                Name = "Modify a feature"
                            modifyInspector[fieldName] = value;
                            modifyFeature.Modify(modifyInspector);
                            if (!modifyFeature.IsEmpty)
                                var result = modifyFeature.Execute();
            catch (Exception ex)
                throw new SystemException((System.Reflection.MethodBase.GetCurrentMethod()!.Name ?? "Unknown") + ": " + ex.Message);
Thanks!
-  David Wilcox
GKmieliauskas
What version of ArcGIS Pro do you use? We have reported bug to Esri for version 3.0. Fixed in 3.2, 3.1.4
BUG-000153875 for ArcGIS Pro SDK for .NET (esri.com)
GKmieliauskas
DaveWilcox
I was at 3.1.3. Upgrading to 3.2.0 fixed the problem. Thanks!
- Dave
