Change addin custom pane icon
1184
5
06-23-2022 04:12 AM
sbayarri_gilytics
Hi! I'm creating an ArcGIS Pro 2.9 addin with some custom panes.
Since the number of visible panes may multiply, I was wondering how to change the default "green button" icon visible in the pane captions, so different types can be easily seen apart.
I tried finding largeImage/smallImage properties in the UserControl XAML for my panes but they don't seem to exist. I also tried setting the LargeImage and SmallImage properties in the custom ViewModel constructors:
// First option: no image is visible
LargeImage = "pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/GenericButtonRed32.png";
// Second option: some kind of exception, the pane doesn't appear
LargeImage = new BitmapImage(new Uri("pack://application:,,,/Module1;component/Images/GenericButtonRed32", UriKind.Absolute));
Any help appreciated,
   Salvador
Tags (3)
GKmieliauskas
I have copied code from my addin. It works as in your attached picture.
P.s.
You can check ArcGIS Community Sample :
https://github.com/Esri/arcgis-pro-sdk-community-samples/blob/master/Map-Exploration/CustomPaneWithC...  Change daml'e  as I wrote above with your own picture
GKmieliauskas
Pane in daml has property smallimage:
      <panes>
        <pane id="My_Pane" caption="My Pane" className="MyPaneViewModel" smallImage="Images\pane16.png" defaultTab="xxx" defaultTool="esri_mapping_navigateTool">
          <content className="MyPaneView" />
        </pane>
      </panes>
Image\pane16.png must be set to AddInContent.
Is it possible to set image on fly I don't know.
sbayarri_gilytics
Hi, Gintautas. Thanks for your answer. However, my pane (generated with the ArcGIS Pro Visual Studio helper) is defined in its own .xaml file, which has this structure:
<UserControl x:Class="myAddin.MapProjectPaneView" ...>
    <UserControl.Resources>
    </UserControl.Resources>
    <Grid>
      My controls go here
    </Grid>
</UserControl>
Not sure if this is compatible with the <Panes> content you describe for config.daml.
Thanks!
GKmieliauskas
P.s.
sbayarri_gilytics
Thanks, Gintautas!  It is clear now. Even if the custom pane has its own .xaml, its icon can be defined by adding a Pane entry in the config.daml with the corresponding ID and class name. It works as expected.
CharlesMacleod
Note: Salvador, the file Gintautas is referring to is the Config.daml and not the user control .xaml (which contains the WPF definition)
