ArcGIS CoreHost application - can't open FGDB - older ArcGIS Pro
184
12-03-2024 02:26 AM
PieterLinks
On my PC with ArcGIS Pro 3.4 and VS 2022 I made an CoreHost C#  x64 application. The assemblies ArcGIS.Core and .CoreHost are Copy Local = Yes and Specific Version = No.
My colleague runs ArcGIS Pro 3.1.3 and the app - after installing .Net 8 - can't open a file geodatabase (but I can!). Instead he gets this errormessage:
System.Runtime.InteropServices.SEHException (0x80004005): External component has thrown an exception.
   at ArcGIS.Core.Internal.Interop.GetInterface(Guid& id, Object& obj)
   at ArcGIS.Core.Internal.Interop.get_Geodatabase()
   at ArcGIS.Core.Data.GeodatabaseUtil.OpenDatastore(String path)
   at ArcGIS.Core.Data.Geodatabase.Open(Uri uri)
   at ArcGIS.Core.Data.Geodatabase..ctor(FileGeodatabaseConnectionPath connectionPath)
   at (my code)
Uri uri = new(fgdbPath);
Geodatabase geodatabase = null;
if (fgdbPath.EndsWith(".gdb"))
    FileGeodatabaseConnectionPath connPath = new(uri);
    geodatabase = new(connPath); // --- here the code breaks ---
else if (fgdbPath.EndsWith(".geodatabase"))
    MobileGeodatabaseConnectionPath connPath = new(uri);
    geodatabase = new(connPath); // here the code breaks I suppose (but not tried)
My question:
- does it have anything to do with the older ArcGIS Pro version? If so, what should I do, unless upgrading all ArcGIS Pro installations?
Many thanks,
Pieter
CharlesMacleod
3.1.3 was .NET 6. he will need to recompile against the .3.1 assemblies.
CharlesMacleod
PieterLinks
Thanks for your answer. After a few days off the office, I've found a workaround: running the program on a virtual server with 3.4 which my colleague can access. I do not have administrative rights so for me this is the only way.
