Access Trace Configuration properties from NamedTraceConfiguration
209
a month ago
jefferson_bzp
TraceConfiguration is currently inaccessible via the NamedTraceConfiguration instance.
Is there any other possible way to access the TraceConfiguration and its properties from a NamedTraceConfiguration instance?
IReadOnlyList<NamedTraceConfiguration> namedTraceConfigurations = traceManager.GetNamedTraceConfigurations(namedTraceConfigurationQuery);
NamedTraceConfiguration namedTraceConfig = namedTraceConfigurations.FirstOrDefault();
The plan would be to use the namedTraceConfig instance to get the TraceConfiguration and then check the properties such as Functions, Filters, Traversability, etc.
Tags (3)
Aashis
by Esri Contributor
You can get  the TraceConfiguration  from a TraceArgument as below:
List<Element> startingPoints = new List<Element> { startingPointElement };
TraceArgument traceArgument = new TraceArgument(namedTraceConfiguration, startingPoints);
TraceConfiguration traceConfiguration = traceArgument.Configuration;
Aashis
by Esri Contributor
jefferson_bzp
Thank you so much, Aashis!
