Why does the 'Find Hot Spots' tool not display anything?
78
05-19-2022 06:33 PM
DarylStiloski
I'm trying to run the 'Find Hot Spots' tool on a collection of points to find cold spots but when I run the tool nothing shows up in my display even when it ran successfully. This is crazy.
DanPatterson
Did you try right-clicking on the layer name and "zoom" to the layer?  It may be in a different location because and incorrect or undefined spatial reference
... sort of retired...
Robert_LeClair
Esri Frequent Contributor
How many points are you using the create the Hot Spot?  Depending on the aggregation method you will need somewhere 30-60 points at a minimum to create the output.  Also is your data in a projected coordinate system or a geographic coordinate system?  If geographic, then you'll need to reproject the data and then run the tool again.
