Using Arcade to pull a value from an Intersect list that is similar to already defined field?
187
4 weeks ago
Amarz
Occasional Contributor II
Hello,
I am attempting to do an Intersect from a point to a stacked polygon layer.  So far my arcade expression returns a list of values, I want to be able to isolate a single value in that list based off a predefined value when creating the point.
Data looks like:
FeatureEAMIT AssetsexampleEAMIT Facilityexample
Fieldsfacilityie: City Hall Floor 1facilitynameie: City Hall
 locationie: City Hall Floor 1 IT Officefacilityfloor
ie: Floor 1
   facilityroom
ie: IT Office
   location
For instance my list will return: ["City Hall Floor 2 Finance Office (261)","City Hall Basement Maintenance Shop (21)","City Hall Floor 1 Open Office (157)"]
What I want is for the arcade script to read my EAMIT Asset is assigned to City Hall Floor 1, and only return the polygon that has a similar name, so here it would reaturn City Hall Floor 1 Open Off (157) into the EAMIT Asset location field.
Here is my script.
//Here is the stacked polygon being intersected
var fs = FeatureSetByName($datastore, "DBO.EAMFacility", ["fullname","facilityname","facilityfloor","facilityroom"])
var fsIntersect = Intersects(fs, $feature)
var results = [];
for (var f in fsIntersect){
//returns all results available
  results[Count(results)] =  (f.fullname)
//what I would like here is to compare it to the established floor the Asset it on and pick the more similar EAMFacility location.
return results
I appreciate any assistance!
