Updating attribute tables after moving points
189
a month ago
CurtisKortemeier
I am new to ARCGIS 3.4, and entirely self-taught. I have a well location database. I have determined that a number of the wells have bad UTM coordinates. I have found the original survey locations in aliquot. It has then been possible to use the edit function and move the well symbol to the correct location. However the attribute table does not change coordinates. I would like to replace the old coordinates. I am not sure how to go about this.
2 Solutions
ZachBodenner
MVP Regular Contributor
You are probably looking for Calculate Geometry:
https://support.esri.com/en-us/knowledge-base/calculate-geometry-in-arcgis-pro-000016157
You can use this tool to get the X and Y coordinates for any point feature.
Happy mapping,
- Zach
BobBooth1
If you select the points you can use Calculate Geometry Attributes on them to add correct coordinate values
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/calculate-geometry-attribute...
ZachBodenner
Happy mapping,
- Zach
BobBooth1
