Unable to connect to portal from ArcGIS Pro after Windows hardening
129
12-04-2022 10:37 PM
shamnasPC
I am unable to access Portal (10.9.1) from ArcGIS pro 3.0.2 after Windows hardening.  When I try to connect, I get the following message: Unable to add portal. Please make sure that the specified portal is up, running and the portal url is correct. However Portal is accessible from browser.
Any ideas what might be causing the issue?
Thank you,
Shamnas
Tags (3)
AyanPalit
The Portal connection string in ArcGIS Pro should use https. Other capabilities like sharing inherit the appropriate URL's.
Manage portal connections from ArcGIS Pro
Ayan Palit | Principal Consultant Esri
AyanPalit
@shamnasPC ArcGIS Pro is self-certified and compliant with Windows Hardening.
https://trust.arcgis.com/en/security/arcgis-desktop-best-practices.htm
Check the obvious like URL and credentials. Since, Portal is accessible from browser - site is allowed/white listed.
Use a tool like fiddler to track web traffic, identify blockage and allow for the portal connection (log Esri Support ticket if needed). Contact your IT Security admin as there are granular configuration settings/Group Policy settings for Windows hardening that may need to be tweaked.
shamnasPC
Thanks @AyanPalit
Yes, I have tried with Fiddler , and getting  below error on the request
request: /gisportal/sharing/rest/portals/self?f=json HTTP/1.1
Response: HTTP/1.1 301 Moved Permanently
So I tried to enable HTTPS only and remove http from IIS, started getting 502 response now, also identified that Pro is always using http to request /gisportal/sharing/rest/portals/self?f=json. Please note, hostname is added to in the host entry to be able to access to portal from the server.
AyanPalit
shamnasPC
Hi @AyanPalit
Yes I am using https, The error in fiddler looks like this
"After the client received notice of the established CONNECT, it failed to send any data"
This is happening only when I connect with Pro, But through browser all good
