I'm noticing that when I clip raster/mosaic data (extract by mask) from a living atlas layer, the clipped result doesn't always retain original symbology (IE all the values get randomly assigned to different colors). I have tried using the GP tool "Apply symbology from layer" also without luck. I also notice that all the processing templates are lost after clipping. Is there a way to preserve processing templates and symbology when clipping, or importing from the unclipped layer that is still loaded into my map? Screenshot attached.
@DanielPhillipsTTU have you tried making a temporary layer from the image service first? https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/make-image-server-layer.htm
Hello @David_Brooks thank you. Yes I tried that route, but the extract by mask that I run on the clipped image service layer doesn't appear to be producing a recognizable NDVI layer, still just a garbled mess of random colors. I try to import symbology from layer (pointing to the original image service layer as the source from which to derive symbology), which doesn't seem to work either. So frustrating!
