The data in the attribute table is deleted with the SPLIT tool
201
05-17-2024 12:20 PM
Labels (2)
JairoCordero
New Contributor III
Hello everyone,
I have any polygon that has an attribute table with data from that polygon,
And when I split it with the SPLIT tool, it deletes all the information contained in the attribute table of the two polygons.
And what I want is for the information to be maintained in both polygons.
I would greatly appreciate it if anyone helps me. Kind regards
Tags (3)
marksm_macomb
Hi there,
If these attributes use domains, then it is likely that your domain split policy is set to "Default". And if you don't have any default values set, then every time you split a feature, that attribute will default to null. In your domains, you'll want to change this to "Duplicate". Esri made it so that all new domains are automatically set to a "Default" split policy which is pretty silly to me.
This is what you're looking for on your domain screen:
marksm_macomb
Hi there,
JairoCordero
New Contributor III
Thank you  my friend. That was the solution.
