Strange behavior when building a mosaic dataset
173
03-04-2024 09:53 PM
mody_buchbinder
I have about 10k tiff rasters.
Each one is 10k by 10k pixels in geo WGS84 and no pyramids.
The pixel size is 25 cm (0.000003 in wgs84).
I build the mosaic and add the rasters. It looks fine but when I check the footprint table the LowPS is 0.000003 (as the pixel size) but the High PS is 0.000086 - why?
Then when I do define overviews each overview on the first level cover about 1000 original tiles and its pixel size is 25 meters.
When I try to show the mosaic there are many scales that shows 200 or more original tiles (since it does not have overviews for this scale) and it draw very slow.
I build many mosaics in the past, never had this problem.
The tiff rasters was created from SplitRaster gp tool on a big MrSID file.
mody_buchbinder
 ended up calculate the highPS to be the same as the lowPS then the overviews was created correctly.
