Smooth the boundary of a buffer into transparency
261
04-19-2024 02:26 AM
GIS_User_1996
Hello!
I was wondering if there is a possibility to smooth the boundaries of buffers around points that in the end NO boundary of the buffer is visible. The transparency of the buffer should increase by moving away from the central point.
Here an example:
What I am searching for is making the boundary of the buffer (red) completely invisible, so the buffer is increasing in transparency. In the middle of the buffer (point) should be the lowest transparency and around the boundary the transparency should strongly increase.
I am not sure if this visualization is possible since a polygon is limited by a boundary.
If anyone has any answers I would greatly appreciate it! 🙂 Thanks in advance!
DanPatterson
symbology : buffered gradient
properties: outline width 0buff.pngbuff2.png
obviously you would pick a less obvious patch color and you can mess around with the pattern
... sort of retired...
AlfredBaldenweck
MVP Regular Contributor
One issue to watch out for is that the Buffer Gradient doesn't support Continuous option, which is annoying. You can get around it by setting your number of intervals higher, but that slows performance.
BobBooth1
I was also going to suggest a gradient fill (and no polygon border color).
https://www.youtube.com/watch?v=LXB9GQCak_A
BobBooth1
