I want to create simple tables in my labels. I thought that using python and pandas dataframe might work, but although the expression verifies as valid, no labels appear on my map. Is there a different way to accomplish this either in Python or a different language? I am using ArcPro 3.1. Thanks
Labels only show strings, s you have to return a string.
I can' test right now, maybe it works with the DataFrame method:
def FindLabel():
table = getTable()
return table.to_string()
If it doesn't, you can try constructing it yourself (untested):
def FindLabel():
d = {"DATE": ["Fall 2018", "Spring 2019"], "RESULTS": [7.1, 8.4]}
# get the column names and the max row count
columns = k in d.keys()
num_rows = max([len(d[c]) for c in columns])
# header in bold
rows = [
"\t".join([f"<BOL>{c}</BOL>" for c in columns]),
# append the values
for r in range(num_rows):
row = []
for c in columns:
# get the value of current r and c, or default empty string
try:
row.append(str(d[c][r]))
except IndexError:
row.append(" ")
rows.append("\t".join(row))
# concatenate the rows with line breaks
return "\n".join(rows)
def FindLabel():
table = getTable()
def FindLabel():
# header in bold
rows = [
# append the values
row = []
for c in columns:
try:
except IndexError:
row.append(" ")
table.to_string() works! Thank you
Can you post a screenshot for how the final product looks? I tried in arcgis pro 2.9.0 but its just text separated by spaces. Thanks.
Here is what it looks like in 3.1. I actually spoke a little too soon. I thought that using the methods here I would be able to format it how I wanted, but having played around, I haven't been able to do so. It also would be nice if there were lines to format the table, but I'm not sure if that's possible.
