SHP to DWG (CAD) export issues
483
01-30-2023 05:15 PM
madxwild
New Contributor II
Hi community,
I am using ArcPro 3.0.3, and am often asked by engineers/surveyors to send my ecological data (shapefiles - point, line and polygons) in a dwg format. I find once I carry out the transformation under Analysis->Export to CAD (output coordinate system the same as my shp files being NZGD Mt Eden Circuit 2000) exporting to DWG Version 2018 often gives the engineer/surveyor skewed or completely distorted data.
I don't use CAD software so have no way to test why it's not working or how I can get a workaround solution around this issue - given that my work is often intensely detailed (i.e. watercourse and wetland delineation) of course the surveyor or engineer will not be wanting to redraw my features from just a georeferenced pdf or jpg file as it'd often take them hours or days to do it. I have no problem importing DWG files and successfully georeferencing them in ArcPro, so the issue is definitely with the way I export my shp to dwg.
Any advice? I have previously tried exporting the shp files to an earlier DGW version (2013) and this often is a bit of a hit and miss (depending on the engineers software they use for their CAD work). I really need a workaround solution, I never had this issue with CAD exports from ArcMap, it only started once I migrated to ArcPro and can't find anything on the interwebs that would help me figure this one out! Any help much appreciated!
ThomasHoman
Occasional Contributor III
Can you post a sample shape with associated dwg export?
Regards,
Tom
madxwild
New Contributor II
Hi Tom,
Attaching an example project with an example of zipped shp files and their associated shp to dwg export (CAD2013 version).
