Setting the web proxy for authentication in Pro 2.3
612
05-22-2019 03:57 PM
AngusHooper1
Occasional Contributor II
I have users working on client machines who access our internal Portal through a web proxy. The IE browser experience is not single sign-on, but the browser does prompt for proxy authentication which passes through and signs the user into Portal. Is there a mechanism to set these settings in ArcGIS Pro? We can see that the Pro session is hitting the proxy, despite no underlying reference to it in the application, so it clearly is picking up on WinINet settings. FYI, we cannot replicate this behaviour with ArcGIS Desktop due to the connections proxy configuration capability in ArcCatalog.
SimonSchütte_ct
New Contributor III
I know this issue is old, but I don´t like unanswered questions :)
With ArcGIS Pro 2.8 there is the option to "Sign In Using Browser" How To: Sign in to an ArcGIS Online or ArcGIS Enterprise account using a web browser instead of the ...
It is possible to manually enable this in In ArcGIS Pro version 2.7.2.
If someone is looking for it - it looks like ArcGIS Pro needs access to:
https://www.arcgis.com/arcgisuris.xml
https://www.arcgis.com/home/signin.html
https://webaccounts.esri.com/CAS/index.cfm?fuseaction=Login.ForgotPwd.ShowForm
https://www.arcgis.com/sharing/rest/portals/[ORG-ID]/?token=*
or when using oauth:
https://www.arcgis.com/sharing/rest/oauth2/ *
