Setting the Display Field
84
09-28-2022 02:13 PM
Craig_Eissler_Iceman
New Contributor III
Hello, so I think I understand that the 'Display Field' set in the Layer Properties > Display section, determines which Field in the Attribute Table is used for a few initial map and data display situations, including LABELING.
But, I have 2 questions:
1. So it's easy enough to "reset" it in Layer Properties, but how is this "(pre)set" to begin with?
2. And, when I "reset" it to another Field, why does it not automatically change (reset) the Label Field setting?
Thanks!
JohnWatt
New Contributor III
Hi Craig - Pro just chooses the first text field it finds as the display field - more of a 'usability' feature, and not specifically associated with cartographic labelling i think.
Good info in this thread:
https://community.esri.com/t5/arcgis-pro-questions/what-is-the-display-field/td-p/742001
New Contributor III
Thanks, John
OK on Question 1.
As for Question 2, I guess I find it sort of strange that the Labeling default field wouldn't change with the Display default field -- since it is preset that way. ...Oh well.
