I'm having trouble using saspy in ArcGIS Pro Notebook and also Jupyter notebook connecting to the ODA (On Demand for Academics) resource. I get the following error. I have followed several instructions for the sascfg_personal.py and the _authinfo file with no success. Here is the error message:
import saspy
sas_session = saspy.SASsession()
sas_session
Using SAS Config named: oda We failed in getConnection An exception was thrown during the encryption key exchange. SAS process has terminated unexpectedly. RC from wait was: 4294967290 SAS Connection failed. No connection established. Double check your settings in sascfg_personal.py file. Attempted to run program C:\Program Files (x86)\Common Files\Oracle\Java\javapath\java.exe with the following parameters:['C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath\\java.exe', '-classpath', 'C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\saspyiom.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\iomclient\\log4j-1.2-api-2.17.1.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\iomclient\\log4j-api-2.17.1.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\iomclient\\log4j-core-2.17.1.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\iomclient\\sas.security.sspi.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\iomclient\\sas.core.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\iomclient\\sas.svc.connection.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\iomclient\\sas.rutil.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\iomclient\\sas.rutil.nls.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\iomclient\\sastpj.rutil.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\thirdparty\\glassfish-corba-internal-api.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\thirdparty\\glassfish-corba-omgapi.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\thirdparty\\glassfish-corba-orb.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\thirdparty\\pfl-basic.jar;C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site-packages\\saspy\\java\\thirdparty\\pfl-tf.jar', 'pyiom.saspy2j', '-host', 'localhost', '-stdinport', '57781', '-stdoutport', '57782', '-stderrport', '57783', '-iomhost', 'odaws01-usw2.oda.sas.com;odaws02-usw2.oda.sas.com;odaws03-usw2.oda.sas.com;odaws04-usw2.oda.sas.com', '-iomport', '8591', '-user', 'lspear@unm.edu/lspear', '-lrecl', '1048576', ''] No SAS process attached. SAS process has terminated unexpectedly. Invalid response from SAS on inital submission. printing the SASLOG as diagnostic
--------------------------------------------------------------------------- KeyError Traceback (most recent call last) In [3]: Line 2: sas_session = saspy.SASsession() File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\saspy\sasbase.py, in __init__: Line 575: self.pyenc = sas_encoding_mapping[self.sascei] KeyError: 'No SAS process attached. SAS process has terminated unexpectedly.' ---------------------------------------------------------------------------
I think I have found a solotion to my post. This should be useful for other SAS and ArcGIS users. It should also be helpful for those at universities that don't have or no longer have SAS licenses. Academic users can use SAS ODA (OnDemand for Academics).
First see SASPy Support to configure and locate these files (sascfg_personal.py and or .authinfo or _authinfo). Also note that three additional encryption jar files (Installation Note) must be added to the iomclient folder at the following path:
Program Files/ArcGIS/Pro/bin/python/envs/arcgispro-py3/Lib/site-packages/saspy/java/iomclient
I hope this helps others that are still using both SAS and Python in ArcGIS Pro.
