"Compute Accuracy For Object Detection" does not find any "True Positives"
193
04-19-2024 03:47 AM
rachbauer
New Contributor II
Hello everyone!
I encountered a problem with the Tool "Compute Accuracy For Object Detection" that does not make any sense to me. Maybe someone of you has any idea about this:
I created a MaskRCNN Model and used it to detect objects in a single image (for testing purposes). I want to see how well this model performs, which is why I use ground truth data of 50 images to compare my detection to (ground truth data covers the single image i used). I can clearly see, that some of my detections (pink) overlap with the ground truth data from that specific image (highlighted in cyan):
However, when i use "Compute Accuracy For Object Detection" it only shows false_positives and false_negative:
If anyone has any idea, it would be of great help! Thanks 🙂
PavanYadav
@rachbauer I am wondering if you tried different values for the Minimum Intersection Over Union (IoU) parameter.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/image-analyst/how-compute-accuracy-for-objec...
https://pro.arcgis.com/en/pro-app/latest/tool-reference/image-analyst/compute-accuracy-for-object-de...
FYI, We have a dedicated board for ArcGIS Image Analyst Questions. Here you may get answers sooner on imagery related workflows.
Cheers!
Pavan
Pavan Yadav | Product Engineer - Raster/Imagery team
THE SCIENCE OF WHERE ®
rachbauer
New Contributor II
Hi Pavan,
I already tried to change the IoU Value. However, it did not change the results :(.
Thanks for the hint with the ArcGIS Image Analyst Questions Link. I guess i will post my Problem there as well 🙂
