Project file crashes after loading layers in content window
187
08-04-2021 02:57 AM
FelixDacheneder
My project file crashes after loading it. It takes some time and layers show up in the content window. After that ArcGIS pro 2.8 crashes. With other project files, everything works fine. Any hints on how to restore the project file? Many thanks, Felix
Robert_LeClair
Esri Frequent Contributor
Not sure if this will help or not but you could try renaming the ESRI folder in the C:\users\<User_Profile>\appdata\local and C:\users\<User_Profile>\appdata\roaming to ESRI_OLD.  Then try to load the *.aprx again.  What is the result?
FelixDacheneder
Thanks for your answer,
I reinstalled ArcGIS Pro and it solved the problem.
