Line Density by Line Count
135
03-24-2023 11:00 AM
Labels (2)
KateDoughty1
New Contributor II
I have numerous lines that I want to create density rasters for, by number of lines, not line length within radius.
I am using Line Density but I must be missing something - my line count is 15,000 but the raster output has a max of over 500,000. Any help or advice is appreciated.
DavidPike
MVP Frequent Contributor
What's your search radius?  Do you have a population field?  The Line Density tool probably doesn't work the way you think it does by counting the lines intersecting each search radius - it takes the length into account also https://pro.arcgis.com/en/pro-app/latest/tool-reference/spatial-analyst/how-line-density-works.htm
What do you (exactly) need to achieve?  You may be better using some aggregation methods using vector only.
KateDoughty1
New Contributor II
Yes, I was reading that it does incorporate length - I've tried numerous search radiuses.
I have 17,000 operations and I want to graphically depict the density of operations/day, similar to the clip below:
KateDoughty1
New Contributor II
I think I found a solution here.
For the extent of my polyline shapefile, I generated a grid using Generate Tessellation. For my purposes, I settled on a grid size of 0.5 acres.
I added an integer field to my Polyline FC, and attributed each record with 1.
To attribute my grid with number of lines intersecting each polygon, I used Summarize Within using my new 0.5 ac grid as Input Polygons, and my polylines as Input Summary Features. For Summary Values, I chose my newly created field where every record = 1, and for Statistic I chose Sum.
Hope this helps someone else!
