Iterator invalidation!The command execution stops partially, which is not a machine problem
128
4 weeks ago
xiangyudong
I use a point element layer to execute the iterator, and the calculation tool is distance accumulation.But when it reaches a certain table and level, that is, this red line, it will no longer run.At first I thought it was a problem with this point, but after deleting a few points, it wouldn't move every time I got there.This should not be a problem with the machine. I changed other layers with larger data volumes and it worked smoothly. Please tell me why this is happening. Thank you.5f61db5d-b9c7-4d2c-8777-9737dd945441.png2008d57d-82ab-438e-8f61-47079f20c3b7.png
