Is there a way to copy parallel?
1920
07-20-2017 06:04 AM
SteveLilly
I used to be able to select a feature and copy it at a predetermined offset distance.
Tags (1)
by Anonymous User
Not applicable
Steve,
The Editor copy parallel tool has not been ported to Pro as yet.
DaveMarkey
New Contributor III
Hi Steve.
If you use an offset distance with the trace tool you will get the same result as copy parallel (press the letter 'o' to get offset options). Use a negative number to offset to the other side of the line feature.
