How to use ArcPy without installing ArcGIS
311
06-17-2024 07:51 AM
TanishqTanmay
I have the ArcGIS Pro license and have it installed on my computer. I run all python scripts on my University's High-Performance computing (HPCC) server which is a cloud based platform. Now, I want to install ArcPy module on my server. Is it possible to do that?
DanPatterson
you can't, Pro must be installed
... sort of retired...
Robert_LeClair
Esri Notable Contributor
@DanPatterson is correct.  The ArcPy package is part of the default Python distribution that is provided by ArcGIS Pro and ArcGIS Server.  You can learn more about it here.
Brian_Wilson
Regular Contributor II
When you try to install the arcpy module on a machine without Pro, it stops with "unable to locate a valid ArcGIS product" etc.
@Robert_LeClair Can you install a licensed copy of arc pro on the server to get the DLLs and then run arcpy there? Obviously Pro is a Windows product so this would not work on a Linux server. But what about Windows?
Robert_LeClair
I don't see why not.  If you're installing ArcGIS Pro on the server, then the ArcPy modules are installed there as well.  Then you can run your code on the server.
