How to create display filter that affects all layers?
138
03-28-2023 08:30 AM
Labels (2)
John1kelly
New Contributor II
Hi y'all.
I am trying to create a display filter that would affect all layers on a map.  I have a database I want to display only points with a desired integer in a field across multiple layers.  So far I can only get it to affect the one layer I am working on.  Is there a way to do this with display filters or do I need to look to a different tool?
John
sarah_maisel
Hi John,
Thanks for posting to Community! I did a little bit of research and it looks like we can only apply filter to individual layers at this time. https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/display-filters.htm
However, I did find this Idea that sounds similar, despite being logged under Experience Builder, I highly recommend you go ahead and kudos this idea. https://community.esri.com/t5/arcgis-experience-builder-ideas/apply-single-filter-to-multiple-map-la...
It would also be a good idea if you went ahead and posted a new Idea under the ArcGIS Pro product area so there is more visibility into this functionality.
Thanks!
Sarah
@John1kelly
sarah_maisel
Hi John,
Thanks!
Sarah
@John1kelly
John1kelly
New Contributor II
Thanks for your help.  I've posted a comment to that post.
John
