How do you Clear a Coordinate System for a GDB Feature Class in ArcGIS Pro?
343
06-14-2024 10:52 AM
Craig_Eissler_Iceman
Occasional Contributor III
How do you Clear a Coordinate System (Spatial Reference) for a GDB Feature Class in ArcGIS Pro?
I used to be able to do this in ArcMap.
Seems like I might be able to assign 'Undefined' in the Define Project tool, but don't see this option.
And, I know that for a Shapefile I can still do this, by just deleting the PRJ file.
2 Solutions
DanPatterson
MVP Esteemed Contributor
Define Projection (Data Management)—ArcGIS Pro | Documentation
If the coordinate system for a dataset is unknown or incorrect, you can use this tool to specify the correct coordinate system.
... sort of retired...
It's the GDB Feature Class that I am wanting to clear. Yeah, I wound up converting it to a Shapefile to do that; then converted it back -- which worked, but was hoping there was a simpler way.
DanPatterson
Thanks, but that is not what I am attempting to do. I'm doing some "testing" and want to "Clear" the coordinate system so that it is undefined.
DanPatterson
for featureclasses in a gdb you can't, for cad and shapefiles, just delete the prj
