how can I optimize a script that requires spatial queries, polygon intersects polygon?
536
06-27-2022 05:54 PM
LuisEduardoPerezGraterol
New Contributor III
Hello
I want to make a script in ArcGis desktop 10.8 for a simple procedure, write for each zone the province that intersects.
The desired result is for the zone layer to have a text field with the names of the province(s) it intersects.
  • The zone layer has 1008 records
  • the province layer has 51 records.
So far, the options have not been optimal, I detail them below
These are my questions:
  1. Is there an optimal way to perform this procedure and to program it?
  2. Does the evaluation of the spatial relations for example: polygon.contains(polygon) use the spatial index or should I activate it?
  3. How can I perform this process using the spatial index?
For this I am writing two scripts, the first attempt was:
- create a cursor on the zones layer
- select the feature with using its ID with arcpy.SelectLayerByAttribute_management
- then select by location with the provinces
- apply a cursor over the selected to get the list of provinces that will write in the attribute
The problem: this takes too long
Second attempt:
- I create an empty dictionary
- apply a cursor on zones getting the shape field and OBJECTID
- Iterate with a for
- for each case I create a province cursor
- iterate on the provinces
- I evaluate which provinces intersect the zone, in the dictionary I store the id of the zone as a key with a list of the provinces. For this I evaluate if the geometry of zones intersects the province geometry, For example: zona.overlap(province)
The problem: it still takes a long time, 1.8 minutes for 40 zone and they are 1008
JohannesLindner
MVP Frequent Contributor
Cursors do take quite some time, so you should minimize them. You only need to instantiate a cursor 3 times:
  1. read the zones
  2. read the provinces
  3. update the zones
You can do everything else without cursors:
# [ [Zones.OBJECTID, Zones.Shape] ]
zones = [ [oid, shp] for oid, shp in arcpy.da.SearchCursor("Zones", ["OBJECTID", "SHAPE@"])]
# [ [Provinces.Name, Provinces.Shape] ]
provinces = [ [name, shp] for name, shp in arcpy.da.SearchCursor("Provinces", ["Name", "SHAPE@"])]
# {Zones.OBJECTID: Zones.ProvinceNames}
zone_dict = dict()
for z_oid, z_shp in zones:
    p_names = [p_name for p_name, p_shp in provinces if z_shp.overlaps(p_shp)]
    zone_dict[z_oid] = ", ".join(p_names)
with arcpy.da.UpdateCursor("Zones", ["OBJECTID", "ProvinceNames"]) as cursor:
    for oid, names in cursor:
        try:
            names = zone_dict[oid]
            cursor.updateRow([oid, names])
        except KeyError:
            print(f"could not find any province names for zone with OID {oid}")
Have a great day!
Johannes
